Does any one in the Lancs area have a C spanner for adjusting rear spring on an africa twin I could borrow or know what size it is so I can order one
You can do it by hand
Squirt the top rings with WD40 or GT85
Use a drift to release the top locking ring
Reach underneath and grab the spring with your hand
Turn clockwise to compress. (do 5 mm at a time to see how that feels)
reset the locking ring when you're happy with the ride height you're after
Much quicker and easier than a C spanner
Be careful not to overdo the compression
So you turn the spring by hand once the locking ring is undone?
Yes, I just used to reach in from the LHS and grab the spring. As you turn clockwise the ring immediately above the spring turn downward increasing the ride height
Don't put too much on in one go, 5mm stages
Good to hear it matey
