1 - 2 of 2 Posts
i found that the inlet is way of balanced on my @ RD07.
question when syncing, how do I know how much air shall past trough on each side when using the guage?
and do someone have any pictures showing where the adjust screws are located?
EDIT: Don't bother guys, found this http://www.xrv.org.uk/forums/how/34010-valve-clearances-carburetor-synchronisation.html
The carb closest to the adjustment screw is the lead carb, you then balance the others to that carb...
Remember, your not actually balancing the carbs, your balancing the vacuum of the engine
1 - 2 of 2 Posts
