Hi All
Can anyone tell me if the 1998 AT carbs fit on the 2000 AT.
I need the choke and this choke on the handlebar doesn’t work for me, it keeps getting stuck! :mad:
And if they fit, where could I get a set???
Born to Slide
Hi All
It would be easir to fix the choke - easyish job but a bit time consuming - search the forum as there is plenty on this. I did mine - huge difference
Hi All
Why not investigate WHY they keep getting stuck? Carbs themselves have really nothing to do for the solution to your problem. They are only part of the cable run from the handle bars that go to the plungers in either carb that give problems. Many many threads on these fiddly little plungers that get stuck and need a cleaning and a lube.
