The mixture on the front cylinder is rich and this foul the plugs up with carbon, which means I must clean or replace them often, the other cylinders fine,I did a trip to Malawi in October last year and had to change the plugs every 2000km. Is this the jets or air/ fuel mixture screwed?
Welcome
Check the choke plunger has not seized or stuck in the carb, this is a common fault
I don't use choke on my RD07a but on the RD04 it sometimes needs a bit of choke
Thanks Paul
I checked the choke , it seems fine. I also checked all the inlet rubbers around the carb and they all fine.
Thanks for the reply
