Ah, it looks like it's one of those times where the expense never stops. No sooner than I get a new tyre (and brake pad set), than I notice that familiar metallic clanging that signifies a new chain is required is here (I think after 22,000 miles this time - not as good as the last chain and sprocket set). I've noticed that on these bikes (TA and AT) the chain signals its retirement by making this noise and sending vibes out, mostly through the nearside foot rest. It seems the clanging occurs when one of the links develops significantly more side play than the others - as it hits the output sprocket (?) it 'knocks'. One chain snapped on me because I ignored it too long, and I don't want that to happen again!
So, my question is, does anyone know if there is a 15 tooth front available? I'm running an extra tooth at the rear, but would like to try a set up that's lower still; standard (45 tooth) on the rear and one down (15 tooth) on the front. Wemoto do the 46 tooth rear sprockets, but not a 15 tooth front. I know the output spline configuration on the 600 and 650 Transalps is different, although the sprocket is a 15 tooth-er, but there must be another out there that fits. If not, I'll just go back to the 46 tooth rear - I would rather not return to standard gearing; the engine just isn't happy in top at 40 mph. Lowering top speed is not a problem. I don't spend that much time over 100, and would rather have more oomph getting there anyway. I know lots of people raise their gearing to try to lessen the vibes, but this just seems to put them in a different place, and makes that around town chuggy-ness worse. And it makes the AT worse off road......
Any thoughts out there?
Stig
Stig
