The fairing on my newly acquired Domi was cracked due to an altercation the previous owner had with a garage wall.
I wanted to tidy it up without spending a lot of money on matching paint and stuff so I decided to do a repair and paint it to match the existing black logos that are on the tank and fairing.
I removed the fairing panel today, 'V'd the cracks slightly on the inside then stitched them together with a hot soldering iron. This done I added super glue with 'kicker'** to seal them off. (Not the rubbish stuff you can buy anywhere but a special heavy duty one for plastics, abs etc.)
**kicker is an American product that when sprayed on superglue causes it to react in a super rapid and strong way. It actually smokes when applied:bom:.
A touch of filler on the outside to smooth it out and then I masked it up to emulate the 'torn-edge' style of the existing black logos on the fairing/tank.
I then sprayed the repair using a semi-gloss black.
Carefully removed the masking and when dry I cut back the black to a reasonable finish.
After a quick spirit-wipe I re-masked the black edges leaving a gap about the same as the clear edges of the existing stickers on the fairing. I then sprayed about three coats of clear lacquer and then removed the masking.
Its now hanging in the lounge (near the fire) to harden and I will cut and polish it tomorrow. (now done)
What do you think, OK, or a bit of a 'Batman' moment
