Hi all,
I am getting a bit nervous. Seems I have a gearbox issue. Fail to shift in 2nd --> always goes to neutral.
The bike is called Shinereay X5. Its an XR400 Motor Clone.
What I checked to far:
- clutch is good, disengaging properly
- shift star is good (can shift through all gears perfectly when bike is not running)
- Oil Level ok
I am running out of ideas.
Maybe somebody can help.
Thanks, Alex from Beijing
Well shifting works from 1st to 2nd but one must do it very carefully. Once you shift faster you end up almost everything in neutral...
Anybody the same issues?
- Shift star works good and is not worn
- clutch is good
- oil is good
Thanks, Alex
