1 - 2 of 2 Posts
Hi all.
Just wondered if there is a certain starting procedure for these bikes.
Bike starts fine when warm or after one day but if left for a few days it takes a while. Usually two goes of the starter. Choke fully out.
Carb has been cleaned. Brand new fuel in tank, good engine compression and a new gapped plug.
Regards
Stone Crazy
they all do that , I think its the modern petrol, it goes off in the float bowl, turn of the fuel tap and let the float bowl empty to stop the engine , I usually turn mine off just before i get home so it stops by the garden gate , if you forget and leave the bowl full then with the tap off open the drain at the bottom of float bowl drain float bowl close drain let bowl fill with fresh fuel and it should start fairly easily
1 - 2 of 2 Posts
