Hi looking for advice, starting the rebuild and was looking at adding a waterproofing element to all connections , what if anything do you use, local parts shop recommend a silicone grease
I use Dow Corning DC4 Silicone Compound
FEATURES & BENEFITS• High dielectric strength• Low volatility• Moisture resistant• Good thermal oxidation andchemical stability• Meets requirements ofSAE AS 8660• Certification to NSF 51 and 61• Meeting requirements of FDA 21CFR 175.300• Retains its grease like consistencyfrom -40°C ( -40°F) to +200°C(392°F)• Odorless• Highly water repellent• Adheres readily to dry metals,ceramics, rubber, plastics andinsulating resins
Indeed DC4 is good stuff. You don't happen to work in aviation? ;)
