New to the group could do with a brain to pick please. just aquired a crf 450 xrl 65 plate the bike had done 29 miles when I purchased it in November after a full nights running fine it just started cutting out if I held the clutch and let the revs die down then won't start for about 5 mins. Any help massively appreciate.
dirty carb ?pilot side if tick over is the only problem and if the bike has been sitting may time for a ultra sonic type of clean they can be real pain to clean .
Is the battery ok ? Valve clearance when out will make the bike hard to start did you try bumping ?Is the bike standard ?
these models can suffer valve issues if its hard to start that would be my first place to check ..If you have a spark ,fuel ,a clean filter ,then check valves
