Had bike a week, all good. decided to give battery a top up. Re-fitted batt, turned key...neutral light on, pressed start slight click... Dead. Nothing, no lights , nothing. Checked batt 13 V. metered ignition switch, ok. Checked all fuses I could find, all ok. Help ?:(
Battery connections clean and tight?
Follow the other ends of the main battery cables and check them.
Next I'd short across the solenoid to see if that gets the starter turning.
Hi Thanks for reply. Checked connections all good. Reading 12.8 volts in batt when it is disconnected, but this drops to 2 volts when ignition is switched on. If I press the horn for example this drops to below 1 volt. Think battery is shot ? Would you agree ? Regards. Mal
