Have an Africa Twin question that I could not seem to google up an answer for.
The rectifier went out on my RD07. Because of the high voltage it goes up to in process of dying, it burned out all the lights, cooked the battery, killed the CDI, and the tachometer also now does not work. It will not go above 2000 RPM indicated no matter what the engine is doing. I have replaced all the other parts , and now the bike runs fine. Except the tach still does not work. To prevent this from happening again I am putting a voltmeter on all my Twins. Has this anyone on this board had the same experience, and is there some tricky fix for the tach ?? I understand they are pretty pricey. Thanks in advance!!
