1 - 2 of 2 Posts
I'm continuing to quietly fettle, clean and tidy the '01 TA 650 I bought recently. After being pleasantly surprised at how easy the tank came off I opened up the airbox. Filter was genuine Honda and in good condition. However, I was disturbed to find a fair bit of dust on the clean side of the filter.
The rubber sealing gasket is in place but I considered whether it needs to be replaced. I then fitted the filter and airbox lid back on to check the fit and found at least three places where the airbox seems to be distorted, creating gaps between the lid and body of the 'box (see photos).
I am assuming this is the likely source of the problem. Is this a common fault with the TA? If so, are there any recommended fixes? If not common, does anyone have any suggestions as to possible cause and a possible fix?
Not seen one like that before.
It looks like someone has tried to force it with the screws still in place!
1 - 2 of 2 Posts
