I've recently purchased a 2000 Model Dominator, unfortunately with no key. I took off the helmet lock at the left hand rear frame loop, and the number inside is 382. I have also taken off the ignition switch, and the petrol cap, which both have N08 or 80N depending on which way you view it. I don't if I'm on the right track to have a replacement key cut ?
I have also looked at the option of replacing the ignition switch, but can only find square three pin connector switches, where the on I have has a circular two pin connector ?
Can anyone help with identification of the ignition switch in this post for my Dominator. This is the original switch fitted to my bike. All the switches I have searched appear to be three pin square block terminals. I would like to keep the bike original without altering the wiring harness.
I have a universal ignition switch fitted at the moment, but would prefer to fit the correct ignition switch if I can identify and source one ?
You should be able to push the spade connectors out of the square plug and refit them into your round plug the third wire is just another switched live i used it to power my heated grips or you can just tape it up :thumbup:
