hello
well, my dominator started knocking when it heats up.
some 2min. after startup.
i think that the needle bearing between the crank and conrod is f**ked
is it possible to replace only the needle bearing and if so what is the part number?
thanx
I think you might have to strip the crank and measure the internal and external diameters of the needle roller...
There are conrod kits available on ebay but they are expensive.
While you have the crank out you might as well to the main bearings while you are there which are listed in the link below.
They are American prices but you can do a google search on the part number and find them in Germany or Poland.
This link covers lots of different bikes and has most of the part numbers you will need.:thumbup:
https://www.ebay.ie/sch/sis.html?_i...+Rod+Main+Bearing+93+09+12+NX650&_mPrRngCbx=1
https://www.megazip.net/zapchasti-dlya-motocyklov/honda/nx650-14678/nx650-dominator-28580/nx650s-709810/piston-crankshaft-11073963
Im afraid this ebay link is dead. Thanx for your posting. I'll post a video of the problem when i get time to record
