Hi, does anyone know where to find, or has a template for this engine clutch side cover that I could print?
I have slipping clutch, I have removed the cover to inspect, but not found anything wrong - all clutch parts within manual specs. I user silicon instead of gasket, but I know I will get inside there again, because I didn't really change anything. I know gasket is better than only silicone w/o gasket, so I would need to make new gasket.
I thought there would be a picture, that I can print, put on top of gasket special paper ant cut it out.
Thanks.
place the gasket material on the cover and use a small ball peen hammer to cut it out
