1 - 2 of 2 Posts
Dead Dommie, no lights nothing. Batt 12.8 volts disconnected. 2 volts connected with ignition on. Drops to 1 volt if i press horn etc. is the battery duff or could something else be causing this. Cheers.
Bloody furriner
2 volts, wow. Knackered battery would be my first suspect, yeah.
Easyish test: See what happens when you wire a spare H4 bulb directly across the battery. If it's dim, you've got a duff battery. If it shines at full strength, there's something else going on...
1 - 2 of 2 Posts
