1 - 10 of 10 Posts
Does anyone know what size bolts are used, to attach handlebar mounts to the triple clamps.
Im looking to buy new mounts, I measured the length of bolt but didnt check bolt diameter, and looking on net, some use M12 bolts but some use M10
Are you talking about the 4 bolts that go through the clamps that hold the handlebars or the rubber mounting bit that attaches to the top yolk
The bolts that hold the rubber mounting part to top yoke.
Would measure it, but can't get into garage for a day or 2
If you mean this bit you cant change the bolt the other bolts are 8mm
Yeah I did mean that bolt, but I'm not just changing bolt, I'm changing whole mounts as I'm fitting oversize bars.
Just needed to know what size the bolts were so I knew what size the hole was in top triple clamp
Its 12mm but its all one piece doesn't look like you can separate it
1 - 10 of 10 Posts
