as any one drilled the baffles on there exhausts and if so there any side affects.and do they sound any better
Dominator? Yes.I took off the chrome rings and made a 13mm hole in the the rear of the exhausts just under the outlet. Sounded and rode better so made another 13mm hole next to the first and filed them into one hole. This was too much in my op as it was a bit to loud.
Had to adjust the mixture as it was then a lot more free flowing.
Would it need mixture adjustment with one hole ?
Yes, slow idle screw out a bit to aid tickover. All bikes are different so you'd have to see how you get on for the rest of the rev range. Already had a .50 idle jet in mine and didn't have to make any other adjustments.
You can always weld up the holes if you don't like the result.
