Hello all,
I need some answears, I am new to my domie!I have changed my chain last week, and I saw that the drive sprocket has a movement of 2-3 mm backwards and forwards.The bolts are ok.My question is :Is the movement of the sprocket normal or not?
I have atached a picture, of waht I mean?
Please help.
Best regards, and ride safe!
Chain too tight is the problem that causes the shaft wear. Many mechanics treat Dominators, Transalps etc as not dirt bikes but "sorta" road bikes and only requiring 20 to 30mm of chain slack instead of 40mm or more.
The shaft erodes because it is rigid but is difficult to repair/ replace, whereas the chain can stretch, and we expect the sprockets to wear out and then replace the lot.
