2000 model
it says 13,000 miles on the clock
are the gold wheels standard on this year?
MOT in 2009 says (see below).....the following. hence from brand new in 2000 to 2009 it only did 1,300 miles? And it wore the tyre out?
i would be interested to hear if people here think the 13,000 miles is genuine
14 May 2009 - FAIL - Mileage 1,338 miles
Reason(s) for failure
  • Direction indicators not working (1.5.1c)
  • Rear Registration plate deteriorated (6.3.1d)
  • Rear Tyre tread depth is below minimum requirements of 1.0mm (4.1.3(ii))
  • Front Roller brake test indicates a binding brake (3.3.A1a)
  • Rear reflector on motorcycle missing (1.4.1)
Advisory notice item(s)
  • Rear Brake disc(s) slightly pitted (3.2.A1l)
  • r/h bodywork loose
165499
Gold wheels are not standard on the 2000 model RD07A .. they were on the RD07 though .. these should be silver wheels.. I assume that they would have been changed at some point with used wheels and tires hence the tires wear. Having said that 20 years old tires would disintegrate at the first occasion of a long ride..
2000 model
Looks a bit rough for 13000 miles but then it is 20 yrs old and may have stood outside. Check the output shaft for wear
