Opening this post just to share the continuing story of my electrical issues, which became more visible after I had Joerg Hau build a voltindicator in my Tripmeter.
But first let me drop my chronicles of the previous weeks. Get some crisps and a Coke cause this gon take a while
31-3: OEM regulator dies on my way to work (fried connector) Had a new one installed which is supposed to be a Mosfet-type, so bigger/better/stronger. Right?
Collected my bike from mechanic a few days later and noticed within 5 minutes riding my rpm-gauge swings up and down in sync with indicator. Also when I switch off my headlights, the rpm-needle slowly but steadily goes beyond maximum(??)
Funny thing is, when headlights are in use, the rpm-meter acts normally. Didn't measure nothing at that point since bike just came from mechanic.
1-4: Sent my Tripmeter to Switserland for revision and have Joerg add a voltmeter to it.
5-4: Had someone add an extra ground-connection from - side of battery to back of dashboard because (as said) 'a bad ground could possibly cause the weird behaviour of the rpm-meter'. Also had my electrics checked and all connectors (contact)sprayed. Had to get the starter relay-connector renewed too as it got partly fried also, probably when regulator died.
All this solved nothing concerning the rpm-meter... At this time I also noticed my temp meter didn't work anymore but the cooling fan did.
8-4: Tripmeter returns from Switserland. Indicates high voltage right after installation. Measured 17 VOLTS!! at battery. When I switched on headlights at that point, voltage is lowering to around normal.
12-4: Replaced regulator with another (new) one from a different brand. Now voltages (measured @battery) are normal again, rpm-meter functions normal again too. \o/
The red undervoltage-light though still is glowing/burning when headlights and indicator are used.
Like the two other posts I found in this forum on this Voltmeter-subject, the red light (indicating undervoltage) is glowing/burning far more frequent than it's supposed to. Mind you, it shouldn't burn or glow at all under 12.8v
When I'm using headlights though (both are burning) and I rev the engine the red light gets brighter (50-60%), even more when rpm's increase towards 50000. When I switch on the indicator too, the red light goes really bright in the same rythm as the indicator blinks (?)
When headlights/indicator are NOT in use the red light is off \o/
I sent an video to Mr Hau showing the voltages measured at the battery (13.8-14.1 @30000rpm) aswell viewing the blinking undervoltage light when using headlights and indicators at the same time. His advice; Have your stator-coils checked for resistance or bad ground. The continuous glowing/burning red light could indicate a statorproblem.
My mechanic however says he can measure the loading capacity of the generator with the 3fases-wiring coming from it, and if that gives the right values the stator is fine. Also he disqualifies the voltmeter right away saying most of them are never right... (I think this one works properly btw)
My question is, will measuring the generator output say enough about the health of the stator? Will that diagnose correctly if the stator doesn't make a shortcircuit somewhere or otherwise have resistance or bad ground-issues? Or should I insist measuring the coils with stator disassembled from bike?
And what about the red undervoltage light burning when headlights an indicators are being used. Can there be some sort of voltage drop or leak in the dashboard area, which makes the red light burn? Can this be caused by a current leakage somewhere which is NOT noticable when measuring loadingvoltage at the battery? Tripmeter seems to work normally (no fading of LED screen indicating lower voltage)
