Can anybody help with the setting up of the front end after fitting these units
setting up of the unit ? (Turns down)
oil level
oil wieght
Cheers agent
Intiminators or Emulators. Both do the same job but are very different. There should be fitting instructions available from the manufacturer with oil and air gap settings
Have order race tech emulators
Just wondering what set up is working for others
Already have progressive springs fitted
There's not one setting for everyone. You can play with oil grade and valve spring tension in order to tune low speed, high speed, damping and rebound.
You should only change one thing at a time to get the best knowledge and range of settings.
Progressive springs shall NOT be used with those valves as far as I know.
Lee
