Hi there,
I have a 99' fx650 which I purchased to refurb and modify. I do not know how it ran before it was dismantled. It was only started.
I have now rebuilt after refurb and I'm having trouble with engine hesitation with throttle open.
I have put a larger main jet (175) as it has a custom end can, with pod style air filter. I have also adjusted pilot screw out to increase fuel ratio.
I have inspected insulator between engine and carb.
Today I removed the air filter to see if the slide is moving up freely when throttle is opened. With the engine off the slide moves up. With engine running it pulses up and down. Is this correct?
Any help would be appreciated.
Thanks.
Thanks.
