hi all, where is the engine oil level supposed to be at on the Honda xrv?
there are 2 marks on the dip stick,when on the main stand, is it between the 2 marks??
thanks for the feed back!!
in the middle is ideal but deffo above the bottom one (min) but not above the top (max) !
Administrator
Don't forget that the dipstick must be unscrewed and just resting on the threads, not screwed in, when "dipping" :)
Sent from my GT-I8160 using Tapatalk
For those of us who are centre-standingly challenged...
What's the ideal level for when the bikes on the side stand?
The bike must be level, just find a wall or lamppost to support the bike while dipping the oil.
Sent from my iPad using Tapatalk HD
Also, it is supposed to be checked hot. So run the bike for 5 minutes then check it. You are able to check it sitting on the bike if you don't have a centre stand. The top mark is where mine sits.
Edited as I put side stand instead of centre stand... Doh!! lol
Oh and make sure your on level ground (sorry for mentioning the obvious) :)
  • Like
Reactions: Catweasel
When i change the oil and filter i also drain the oil out of the oil cooler .... i then fill it with 2.9 ltrs and its bang on .....:thumbup:
