Hi has anyone ever fitted an exhaust extractor in your workshop
I have seen them in workshops basically a length of flexible hose with a rubber cone that slips over you end can then the hose runs thro a extractor fan then out thro the wall like a tumble dryer vent not sure how powerful fan would need to be to cope with an engine runing/reving in
any ideas :confused:
Stone Crazy
would have thought any pipe that directs the fumes out would do gonna need a pretty tough extractor to stand the fumes though
a standard vacuum cleaner motor should be sufficient, as it is only the bag clogging that causes loss of suction.
yet another Dave
as has been said, you dont need an extractor, just a hose from the exhaust to outside is plenty. its going to get quite hot so a metal end peice or a water hose from a car will be a good idea.
The Army used to use a slip on hose for the Land rover so they could keep the batteries charged up when using the radios.
My Blue Beast
i`ve always found that after 10 pints and a massala you cant beat a gentle waft of the duvet in the general direction of the other half. guaranteed to get a response !!.........( usually a good dig in the side and a very un-ladylike mouthful :rolleyes::rolleyes::rolleyes::rolleyes: :D:D:D:D:D:D..........oh sorry thinking out loud again..........pipe plus metal heat shield:thumbup:
yet another Dave
so you could run the vehicles engine to keep the batteries charged up, (radio transmitters use a lot of juice) and pipe the exhaust away from the basha/tent/barn/wherever youre hiding so as not to kill off too many brain cells, them squaddies dont have many to spare!
if its like the old fashioned ones ive seen its a like a sort of funnel and long hose that you jam over the exhaust. the ones we use on our flight pan bowsers and cranes have a quick release fitting on the exhaust so we can use them inside the hangers, a bit like a larger metal hosepipe fitting.
