1 - 19 of 19 Posts
Just a wild idea guys...
I love my @ but I'm dreading the day when I've dropped it when no-one's around for miles or hours as I've never quite been able to lift it myself. I dream of green laning it - at least on something fairly dry and level - but I can imagine adding soft or sloping ground into the mix could make it almost impossible to lift unaided.
I've been idly pondering equipment that could help. I love this guy's rear mounted winch on his KTM ADVrider - View Single Post - winch on a motorcycle :D which would help pulling it out of mud but I guess couldn't lift a dropped bike if there weren't any trees or high anchor points around.
Anyway this evening I spotted these Exhaust Jacks | ARB 4x4 Accessories » Products » ARB Recovery Equipment so called Exhaust Jacks. What an ingenious idea! ;) The smallest I've been able to find so far is rated for about 3 tonnes, weighs about 5 kilos and I think is about 50cm wide, so yes very big and bulky for a bike I admit. I'm just curious if anyone here has used one of these and got any thoughts whether it could be made to work with an @'s exhaust?
I figured as they're soft and collapsible they could be squeezed under the bodywork of a fallen @ and inflated enough to be able to lift it easily even in the mud, without damaging the bike. What do you think?
I read on a 4x4 forum somewhere someone said a vehicle can tend to be pushed off it sideways if it's inflating at an angle - and I guess it wouldn't be a level surface under the bike :( Maybe it could be tied in place?
Please, what are your thoughts guys? Am I nuts? :happy6: Any better ideas other than working out til I look like Arnie? ;)
Those inflatable ARB jacks have been around for years only problem with lifting a bike with one once the bike gets up to a certain angle the jack would probably fly out like space hopper or football then you would be back to square one,, you could always try a ground anchor and manual winch or just go out riding with a mate and use the old buddy buddy system
Not trying to be smart but do you know how to lift your bike? Put your back against it, squat down and lift with your knees. Yes, she's heavy, but with the right technique you may find that it's not too bad. With a few mates around it may be a good idea to gently lay her down in the grass and practice picking her up if you're concerned. Better to learn how & know you can do it in a controlled environment instead of a muddy slope. :thumb:
Thanks, I do know the lifting theory yes, although I will add it's hard to get your back against a bike without panniers that's almost horizontal. Here I'm interested in exploring the options when those methods still aren't enough.
Agree there about learning how to lift.
Had a beemer for years and dropped her a few times. Needless to say my back was kna**ered afterwards. Recently I went on a one day session with an experienced off road rider offering lessons and learned two very good tips that day. 'How to recover a bike off a hill and how to pick up the heaviest of bikes quite easily'.
Make sure the bike is in gear, lock the steering to one side, grab the handlebars with bent knees and lift from there. Its amazing how easy it is.
As mentioned. Lay the bike down with the help of some mates and try the above (but) make sure its in gear, otherwise it'll run away from you as your lifting.
Hope this helps.
Mike
Thanks. I still wonder if the jack could be held in place somehow.
I can't figure out how I'd lift a bike using a winch and ground anchor when the ground is lower than the parts of the bike that need lifting? Wouldn't that just drag or rotate the bike along the ground down towards the anchor?
If you're bikes in its side it has probably got a sencer to kill the engine so no exhaust gasses to fill the bag, if the bike can run on it's side do you realy want to run it?, if you still want one try "cpc.co.uk" they sell them at what seems to be a reasonable price.
one of the lost boys
Stuarts right your bike will probably not run on its side the other thing is those jacks are designed around big engines 6, 8 cylinders with enough power pushing out through the exhaust to inflate the bag, if you were to fit one to the bike the engine would stall,
probably
Another vote for practicing your picking up technique.
I'm not exactly He-Man and I have no problems picking up my 1150GSA with a full tank of petrol. The XRV is a piece of piss compared to that!
The trouble with the jack technique is that sooner or later your gonna have to get between the jack and the bike and if it slips at the wrong moment you will be pinned to the ground at best or worse pinned to ground whilst a pack of wild hedgehogs dump in your beard.
Having dropped and picked up the Africa Twin on countless occasions I would have to agree with the practice method.
Even if you can pick it up by yourself you still cannot go green laning because the most likely scenario offroad is that your leg gets pinned underneath the bike - so you need to be in pairs at least, Therefore it will be a problem halved anyway.
+1 for practice.
I threw my Vstrom down the road a couple of months ago, even though it was on a nice level hard road I still figured I'd have trouble lifting it on my own.
Until I actually tried it! Adrenalin helps a lot if your hurt but if not then with the right technique you'll be amazed at how easy it can be.
This site contains some good examples....
Pink Ribbon Rides
Axe.
Discussion Starter · #14 ·
+1 for practice.
Pink Ribbon Rides
Axe.
Thanks, I hear what you guys are saying about technique and practise. To be honest I've spent ages reading sites online about this and yeah I had seen the above link (only thing is that bike's got panniers so it's easier for her to get her butt against it. I might still get some for the @ but they'd make it pretty wide to back through our gate etc).
I've dropped it about four times so far :rolleyes: and every time I tried the techniques I'd read about (turning the bars, bending my knees and lifting with the bars, as well as the using my legs to push my back against it) I just still couldn't seem to muster the physical strength to do it. I'm sure some of you guys are stronger than me. It probably is partly also though that someone came to help every time. If I'd been there another 15 minutes alone maybe I'd have cracked it. It seems to be more the top heaviness and how flat on the ground it falls rather than just purely the weight itself.
Still, I will give it another go at some point, maybe lay it down on the grass when the tank's nearly empty. It is possible that there are bits of my technique I can improve - for example leaving it in gear - I can't swear I always did that.
Of course real world situations are always harder. Usually the tank is nearly full, the kick stand has embedded itself in the mud and your feet slip (mud - remember?). Sounds like my last weekend in Wales!
Discussion Starter · #16 ·
Sounds like you made it out though! Cool! Any pics? :)
Of course I never remember to get the camera out when the bike is on its side and fuel is pouring out of the carbs. :( Oh well. I need to work on remembering to take photos instead of fixing the situation.
Discussion Starter · #18 ·
I meant of the ride not the off but never mind :rolleyes:
1 - 19 of 19 Posts
