Well the only real cockup of my recent build has come to light and that's the BBQ. I've built it too wide.
I built the first one about 15 years ago and I don't remember cutting the blocks on the first course as it was exactly 2 blocks wide. Well either blocks have got about 15mm longer or I did cut them but regardless its now about 25mm too wide and the grill isn't long enough for the hooks.
I did cut a slice of a 1" paving slab and fitted that to the inside but it looks crap. What I really need is something thinner that I can put on both sides and that way it evens things up. I was looking at cement board but at 6mm I'd need two layers each side.
Any idea what other sheet material I can use that 10-15mm thick and fireproof? I don't mind if it's not weatherproof as I can remove it when not in use.
