2001 650 Transalp
I have bought some braided hoses to fit, but I am a bit confused how to go about it, I am not even sure I have been sent the right ones.
see pics
there are three bolts and two hoses. the hoses are long enough to go from the brake reservoir to the calipers.
do i remove ALL the existing hoses? ie even the "rigid" higher section of the existing hoses?
do i attach the two new hoses to the reservoir with the longer bolt? because with the existing setup there is one hose coming from the reservoir, which then enters the "rigid" section and splits into two
help!
164853
164854
Yes both hoses go on the longer bolt at the master cylinder up on the handlebar and you strip off all the old stuff. When you route the hoses down to the brake calipers have a look if they are resting on anything as a braided hose will rub groves in things where a rubber hose wouldn't over time
oh i see, thanks. i have fitted them
if anyone want the old ones for free. let me know! they are only 19 years old
164857
