Hello everyone.
I am planing to change my front wheel bearings and i have been researching online on how to proceed.
I am getting confused as most the videos that i have found out there the procedure to change the bearings does not require the removal of the brake discs. But according to honda manual that i have downloaded, the procedure requires the removal of the Pulser ring and the disc brakes from both sides. :(
Is this really required? Or they just been too cautious as to not damage these on the process?
Cheers.
adasilva
Hi, I’ve changed wheel bearings on my transalp without removing discs and pulser ring, you must do this gently, i mean do not scratch discs, I put wood under the wheel
Wysłane z iPhone za pomocą Tapatalk
Thanks mazak
i kind thought that it could be done without remove these.
i will have a go once i get my new bearings set.
Cheers.
