Quick question...Does anyone know the diameter/length of the little screw that holds the fuel selector to the fuel tap please?
No...............But as mine was broken I'm now using a flexible 6" length of hydraulic pipe pushed over the square tap and it works perfectly for turning on and off ! ....... ( For now :cool: ?)
Old fool, but i'm alive..
Its not a standard screw, basically its a 5x19mm, but has a 6mm shank of 10mm long...so its a special screw...not over the counter type thong...
Put differently, its 19mm long, has a 10mm shank of 6mm, then the last bit of thread thats 5mm...hope this helps...
