When putting my bike back together I found the fuel tap is leaking when in the off position, I had lost my patience in the excitement of hoping it was going to start, to open up the tap and see what was wrong.
So anyway the bike fired up as normal
but it looks like I have a sticking float valve as I'm leaking petrol from the carb drain pipes when the ignition is on and when running so it's a further strip down to look at this
Is there a redress kit for the tap, I need to fix this as I should have done before refitting the tank!
TIA
John
TIA
John
