So, the clocks have gone back and the evenings are getting darker.
Que time for figuring out how I'm going to light the garage so I can at least get the bike in and out without loosing my gloves.
I've been using a big rechargeable spot light, reflecting it off the low ceiling, as it and the walls are white. Works okay for a while but as it gets cold the charge lasts less and less. Also, after 2 years it's starting loose it's life with seasonal use.
I've only got the booster battery emergency lights which are 2 Eco bulb things. I can see the floor at least.
What's your best ideas given it's not possible to wire it as it's detached and has a shared tarmac drive between house and garage.
Normal size brick garage, walls and plaster board ceiling all painted white. Not much shelving on sides as most junk is at back.
Help!
Help!
