A
africatijn
·Guest
Hi,
I know some of you have a Garmin GPS-V.
As of the end of february, the new map update is available. In addidtion to this the CitySelect is replaced by City Navigator. So City Navigator V8 will replace City Select V7.
Now, some people have installed the CN8 maps, and the problems begin. The "map tiles" you select for downloading the detail information are much much bigger than compared to CitySelect7. This combined with just 19Mb of memory leads to very limited map material you can download (I was told you can only pick 2 map tiles or so.... So choosing a long route via small tiles is not possible any more.
Garmin doesn't warn you for this, because in effect the update is possible....
I have the update at home, with an unlock code, but I decided against it to install it.
Cheers,
Tijn
Cheers,
Tijn
