I can ride all day.
Hi guys. My xr250 is set up for expedition use. It doesn't use a battery. I'm looking into satnav gps options. The problem being I can't power anything from the bike.
I have a small garmin bike unit which will last around 6 hours then need 8 hour charge. Not ideal was thinking of a solar unit for this maybe?
Will be camping so power will not always be there.
Or any other suggestions? Or has anyone be able to run a gps for a xr
Sent from my SM-G920F using Tapatalk
I can ride all day.
Just check the power consumption of what you are charging to make sure you get one with enough output
I was thinking about current rather than volts. I just connected my old nuvi sat nav with an ammeter in line and it was drawing just under 0.5amp with a flat battery so anything with 1 amp or more output should be ok
  • Like
Reactions: insainwayne
