Hello,
After change of clutch plates and springs on my AT RD04 750 1992 there is strange problem. When accelerating in first gear there is grinding sound (metal on metal). It starts at the moment of clutch release and last for one or two seconds. No problems in other gears or at any other situation. It disappears after engine gets warm.
Does anyone have any clue?
Thank you in advance for any advice.
Sent from my Redmi Note 8 Pro using Tapatalk
Did you cover the clutch plates in oil before fitting them could be dry plates
Hello,
Same issue, when I try another engine oil. I use motul 5100, and replace with Motorex. Then sound come. After about 200km, change back to motul 5100 and now work perfect as before.
Recommendation, change oil immidiatly.
Yeap, maybe problem is that I didn't change oil...
