Hi everybody
I have a Honda varadero XL 1000v the latest model.i have been trying to find good led bulbs to install them . The headlight of the varadero is suitable for installing led lights? Does anyone knows by experience which is the brightest h4 led?
Thank you
If the goal of LED bulbs on your motorcycle is to provide better visibility, it's important to make sure that the model you choose is bright enough to provide you with good lighting. The intensity of LED bulbs is expressed in lumens, and the higher the intensity, the more powerful your bulbs are. To make the right choice, be guided by your needs. If you are used to driving at night, you should choose a very intense model similar to such lamps vont.com. For example, with a 6000 lm LED bulb, you can drive safely at night. However, you should not go overboard with this when it comes to the intensity of your LED bulbs.
