Hi folks
Where can I get 25mm straight handlebar risers for the TA. The type I am after are the ones that fit into the original lower half of the of the original ones, then use the existing top bit. Thanks fat-mal :confused:
eBay jobbie - search for this description.
Handlebar bar risers Honda XL XR V Transalp 25mm BLACK
Seller:
Tony Edgley
Telford, Shropshire TF1 7XU United Kingdom
FYI - I ordered 25mm but they stretch the brake lines too much so I went with 20mm.
Oh - and they all fit under the bar and use original tops - supplied with nice SS long bolts too.
E-bay. I used 25mm risers after considering 30mm ones. The only problem i have now is when im on full lock to the right it tends to pull the choke cable and stall the bike :confused: It does not affect my brake lines because i fitted HEL S/S ones. But you will find you have to fettle a little with the oem ones. (well i did with the 650).:thumbright:
