Witch relay is the headlamps/lights .... ive got a intermittent problem with them doing what they want ... the main beam does not work nore does the side lights ... when there on there very dim and yellow in colour ... i surpose it does not help when your running 2 900 lumin spot lamps :D
Depending on your model you could have 2 relays. On some Euro models their may only be one relay. Very good troubleshooting info in Haynes chapter 9-7 with good pics
of relay locations.
If you have an RD03 or RD04, there's no relay at all as fa as I know. The 35W goes directly into the the small wires and switches. When I fitted twin H4s on my RD03, I added two relays. One for the highs and one for the lows. I had RD07a headlamps, and therefore could run two highs and two lows. Now, very small current (negligeable amount) goes thru the original wiring and switches.
