Hi all. Am mackling together a headlight guard from some leftover st/steel mesh. Its fairly heavy duty stuff but confident itll look brill if I get it all welded and mounted properly.
Three important questions before I get going tho:
One – is there a legal restriction on the amount of coverage by the grill (ie 'blocking' light from the headlamp units)? and is that why touratech stipulate 'for off road use only'?
two – whats the best method of welding a good grade of stainless? I have read that gas arc is the best way forward? (I will need to recruit someone to do this for me)
three – I have a problem fixing the guard to the bolts under the nose at the front (see TT's example below) since one of my bolting points is chipped off at the corner of my fairing. Anyone have any ideas of where else / how else to fix this more robustly – as I said it does weigh some...
or should I tap some new usefully positioned bolting points – like through the metal plate which sits behind the 'nostrils'??
Any handy tips welcome !
