its just a ride!
Found a lovely sample of mesh in a skip – stainless 316 – thought itd make a nice headlight grill!
Had a few issues fitting it since I have a bolt missing under the fairing so tapped a couple of holes in the splashguard under the nose and used threaded bars for bottom supports (not the most aesthetically pleasing solution but does the job).
The top bracket is made from a bit of stainless door lock plate with a rubber spacer behind.
Its strong – could throw a brick at it!
Wont rust!
Tighter than usual mesh pattern stops smaller stones getting through.
And I have another sheet which I am hoping will fit as radiator grills!!
A very neat piece of work and looks good for purpose it's intended for, well done:thumbup:
Nice job:thumbright:
I'd have put some radii(radiuses??!) on the edges of that top bracket though:toothy10: .....​pedantic? moi?
