Afternoon. My first post here.
Just acquired a scruffy 2002 Transalp 650. However, all seems reasonably sound with history etc.
However, clutch seems very heavy, even with new cable. Before I dismantle, any thoughts please?
Perhaps just bunged up with crud from the past 36,000 miles?
Hi...As long as it's not slipping or dragging and it ain't the cable your ok ! maybe on it's 2nd clutch and someone has fitted heavy duty springs..I WOULD... Honda XL650V XL650 Transalp 2000-2007 Set EBC Heavy Duty Clutch Plates & Springs....ebay and as you describe...I have a set in the waiting pile and expect exactly what you have
xrv750x Pilot
Make Sure the Clutch Cable Run is Correct and No Sharp Bends or Kinks in it , Its so Easy to Fit incorrect and then find the Clutch Very heavy . Did you fit the Cable or Previous owner ?
Thanks your responses. I'll double check the cable routing and was also wondering if someone has fitted heavier springs. I might also look at lever with adjustable fulcrum as on another bike this made a big difference. Also, clutch lever free play stated as 10-20mm; that's massive!
10mm to 20mm at the lever end is spot on always found it good on mine, be a good idea to pump some oil down the cable with a cable oiler also check the outer where the inner comes out at the clutch end that it is set at the best angle I set mine by watching the inner slide in and out as I work the bar lever, its a typical place where the inner will rub on the outer and fray.
Thanks. There's also quite a lot of free play on the clutch actuating spindle, before the light spiral spring is under any tension. Anyway, I'll investigate this all more methodically at the weekend. Thank s
Quick update. New clutch cable, properly routed and all sorted. I was just fearing the worst on a new purchase.....
What’s the routing like on the new cable? It needs long smooth bends wherever possible, no kinks or tight bends.
My 600 clutch is a two finger job, I’m tempted to cut the lever down to make it easier to operate while gripping the bar with the other two fingers.
