My brake switch isnt working on the rear brake i have bought new switch but cant find anything about how to get to it? or how to dismantle it...?
Anyone offer some advise or diagrams?
Thanks in advace
your welcome that's a pity . I would imagine its connected to the calliper when you push on the pedal the switch is allowed to open completing the circuit and lighting the bulb . I have never worked on a rear hydraulic brake light switch only drum and the front when you pull in the leaver the switch opens . ask google or you tube I am sureits much the same principal across all bikes . its quite on hear this time of year .
The rear brake switch is down near the brake pedal and is attached to the pedal by a (weak) spring, the switch is just clipped in to a bracket on the frame.
They are pigs to adjust correctly so your current switch may be ok and just wants a wobble or adjustment.
Spot on thanks!! just adjusted it and its working again. shame i already bought the switch ha. But yeah total bitch to get at.
Thanks!!!!
