S
Guest
I have put waypoints and a route on the laptop and then supposedly sent it to the data card via the USB reader, however when i put the card into the unit and look for the waypoints and route they are not there, anything i'm maybe not doing right?:(
aka Oxbone :)
***Put the data card into the reader before you send the data from the pc...***
Copy n paste or drag n drop should work...
have you used windows to check that the data IS ON THE card before you remove it and put it into you SP111?
If its not working .... try formatting the card... (back up first tho)
S
Guest
i even put the card in and selected read from the card and it brought up the waypoints and route but not there when its in the SPIII unit! Figure that out.:confused:
aka Oxbone :)
If the card has been used before on some other type of hardware the FAT might be blocking the SP111 from reading it...
Reformat the card Simon.... is it SD?
S
Guest
no its a card only used on the SPIII and was brand new when i used it. It works fine for loading the maps but its just this that the problem.
