Suspected piston rings onway out!! Wen i come off the throtle wen slowing down the bike smokes an is buring oil. I was wondering if ther was a seal what mite of gone whats letting oil into the cilinder because it still has good cimpresion.
Any infomation would be a great help
Valve stem seals or valve guides.
Seals are an easy thing to try.
Valve guides need specialist engine machinist's work.
Either way you need to strip down your engine.
Sent from my G7-L01 using Tapatalk
If you are using large quantities of oil then you may well be correct in suspecting your piston rings.
It could also be the valve stem seals which would cause the problem you describe.
If you want to fix it ,you can buy a top end refurb kit that includes the gaskets and stem seals so if you plan to do it then you may as well check your piston rings while you there..
What sort of miles has your bike done?
Buy genuine Honda stem seals. Seriously. Or Viton if you can get them....
A whisp of oil smoke on the over run is often a stem seal or valve guide. If your rings are gone you generally get smoke all thr time. Especially at high rpms.
Nothing is that simple though. You can do a compression test but you MUST take the decompressor out of the equation by setting the RH exhaust clearance to about 0.50 or more.
Hey Mototed,
It sounds like this guy is having the same problem as I had when I bought my Dommie that had been stood still for 10 yrs in Germany.
Nothing that cant be fixed.:thumbup:
Which part of the Wirral are you from ,I got mates that defected there from over the water to live there?.:D:D:D
I'm in Birkenvegas. Thr promised land over the water. Where the street are paved with gold and young maidens dance by moonlight ?
I was born over the water in Wave a tree but we got out sharpish and moved to St Helens which is nothing to brag about and that why I emigrated when Thatcher was voted in....Aufwedersehen Pet kind of thing.:thumbup:
my slr was very smoky when i first got it,a tad too much oil and it would smoke like a 2stroke,i drained and refilled with the right amount rather than using the dipstick regular and it was sorted.all the best
