when in situ which way does the starter motor pinion rotate mine is going clockwise, is this correct?
Can a starter motor have its polarity changed ?
when I took the cover off to sort a starting problem I started the engine no spark.
ALL Electrical components parts are working, and checked to be correct . New spark plug, coil works fine , cdi works fine ,pulsar coil new.
timing is spot on, valve clearances correct, battery good
your thoughts and ideas as always very welcome
