Hi all
I’ve changed my indicators to led, l can’t seem to get them to work properly , I’ve replaced the relay with one from rugged roads and changed the bulb on the dash to led also, the problem is if I turn on the left indicator the right comes on also but very dim, the dash lights up but if I turn to the left the dash won’t light up but the indicator does, I’ve tried switching the bulb in the holder as suggested after a quick search of the forum but getting confused, wiring isn’t my strong point. Can anyone explain in layman’s terms or have an idiots guide as to where I’m going wrong
You can also buy diode bridge in one package.
Alternating current inputs (bridge) connect to left and right blinker. Positive output (bridge) connect to idiot light.
Good luck!
Sent from my SM-J600FN using Tapatalk
