1 - 11 of 11 Posts
Hi, I usually write at XTZ750.com, and that's where I found this forum.
My 2001 Transalp has 2 unrepairable radiators (just rotted away), and I have a friend comming to the UK next week who is willing to bring them here for me, where can i find radiators, preferably used ones, but if those cant be found, where can a get new ones for a reasonable price?
I found a right hand one on ebay.uk, but I don't know from what model they are, what years will fit my bike?
thanks, Gray.
Welcome to the forum,
I would personally try David silvers and get new ones, as you live so far away, that way you would be sure they are correct and they should then last.
Discussion Starter #6 (Edited)
I found this in ebay.de :
Transalp XL 600 V XL600V PD06 biede Kühler + Lüfterrad
Will this fit a 650 or do they have different rads?
I have asked the seller and he has no idea.
from the spec (the one I found here):
600:
Cooling System
Coolant capacity: Approximately 2.0 litres.
Radiator cap opening pressure: 13 to 18 psi (0.9 to 1.25 Bar)
Thermostat:
Opening temperature: 80 to 84º C (176 to 183º F)
Fully open: 95º C (203º F)
Valve lift: 8.0 Mm (0.3 in) minimum
Standard coolant concentration: 50% mixture with soft water
650:
Cooling System
Thermostat:
specs look the same, has any body got experience with this? has any one got part numbers that can be compared?
new ones are 450£
and a used pair is 129 Euro.
Thanks.
Not sure but for that price I would be temped to get them and make them fit.
hedgerow specialist...
Is it not possible like in cars/vans to get new cores and use the outers and have someone local to you weld them up?
Discussion Starter #10 (Edited)
in this case-the pips are fine, the bottom of both sides has rotten away.
I have found an other set from a 2005 650 for 150 Euro, I think I'll just take that one.
1 - 11 of 11 Posts
