1 - 1 of 1 Posts
SPECIFICATIONS (from the manual)
DIMENSIONS
Overall length:
2,315 mm (91.1 in) ...E,F,ED
2,380 mm (93.7 in) ...G,SW,AR,II G
Overall width:
905 mm (35.6 in)
Overall hight:
1,430 mm (56.3 in)
Wheelbase:
1,565 mm (61.6 in) ...E,G,F,SW,ED,II G
1,560 mm (61.4 in) ...AR
Ground clearance:
215 mm (8.5 in)
WEIGHT
Dry weight:
205 kg (452 lbs)
CAPACITIES
Engine oil:
(After draining) 2.4 l (2.5 US qt, 2.1 Imp qt)
(After draining and oil filter change) 2.6 l (2.7 US qt, 2.3 Imp qt)
(After disassembly) 3.2 l (3.4 US qt, 2.8 Imp qt)
Fuel tank:
Total: 23 l (6.1 US gal, 5.1 Imp gal)
Reserve: 5.1 l (1.35 US gal, 1.12 Imp gal)
Cooling system capacity:
2.03 l (2.15 US qt, 1.79 Imp qt)
Passenger capacity:
Operator and one passenger
Maximum weight capacity:
196 kg (432 lbs)
ENGINE
Bore and stroke:
81.0 x 72.0 mm (3.19 x 2.83 in)
Compression ratio:
9.0 : 1
Displacement:
742 cm³ (45.3 cu-in)
Spark plug:
Standard: DPR8EA9 (NGK) or X24EPR - U9 (DENSO)
Cold climate (Below 5°C, 41°F): DPR7EA9 (NGK) or X22EPR - U9 (DENSO)
For extended high speed riding: DPR9EA9 (NGK) or X27EPR - U9 (DENSO)
Spark plug gap:
0.80 - 0.90 mm (0.031 - 0.035 in)
Idle speed:
1,200 ± 100 min–¹(rpm) ...E,G,F,ED,AR,II G
1,200 ± 50 min–¹(rpm) ..SW
CHASSIS AND SUSPENSION
Caster:
27°30´
Trail:
133 mm (5.2 in)
Tyre size:
Front: 90/90 - 21 54H
Rear: 140/80 R17 69H
POWER TRANSMISSION
Primary reduction:
1.763
Gear ratio:
1st: 3.083
2nd: 2.062
3rd: 1.550
4th: 1.272
5th: 1.083
Final reduction:
2.812 ...E,G,F,SW,ED,II G
2.687 ...AR
ELECTRICAL
Battery:
12V - 12AH
Generator:
0.36kW/5,000min–¹(rpm)
LIGHTS
Headlight:
12V - 60/55W x 2
Stop/tail light:
12V - 21/5W
Turn signal light:
Front: 12V - 21W x2
Rear: 12V - 21W x2
Instrumental lights:
12V - 1.7W x4
Neutral indicator light:
12V - 3W
Turn signal indicator light:
12V - 3W
High beam indicator light:
12V - 1.7W
Low oil pressure indicator light:
12V - 3W
Side stand indicator light:
12V - 3W
Position light:
12V - 4W
Maintenance and servicing specifications
Valve clearances (COLD engine):
Intake valves: 0.13 to 0.17 mm
Exhaust valves: 0.18 to 0.22 mm
Torque settings:
Oil drain plug ................................ 34 Nm
Rocker arm adjusting screw ............. 23 Nm
Spark plugs .................................. 14 Nm
Steering head bearing adjuster nut ... 11 Nm
Steering stem nut ......................... 128 Nm
Top yoke fork clamp bolts ............... 27 Nm
Shock absorber mounting bolts ......... 44 Nm
Front fork top bolt ......................... 23 Nm
Front fork clamp bolts (Top yoke) ..... 27 Nm
Front fork clamp bolts (Bottom) ........ 33 Nm
Swingarm pivot bolt nut ................. 106 Nm
Brake disc bolts ............................ 42 Nm
Brake hose banjo bolts ................... 34 Nm
Front axel .................................... 64 Nm
Front axel clamp nuts ..................... 12 Nm
Rear axel nut ................................ 95 Nm
1 - 1 of 1 Posts
