This is most definitely a “work in progress”, so any additional info gratefully received.
These specifications are intended as a guide and do not constitute official measurements or specifications. If you are unsure please get a Honda approved mechanic to check or maintain your bike.
All units in millimetres mm (inches in) unless otherwise specified.
Honda XL700V
Covers the years: 2008 onwards (V-8)
Please post up specs of other variations if you have them.
Pictures
Dimensions
Length: 2250 mm (88.6 in)
Width: 905 (35.6 in)
Height: 1305 mm (51.4 in)
Wheelbase: 1515 mm (59.6 in)
Seat height: 841 mm (33.1 in), low seat option 821 mm (32.3 in)
Ground clearance: 177 mm (6.97 in)
Kerb weight: 219.0 Kgs (481.8 lbs)
Frame
Frame type: Single downtube with double loop cradle of rectangular section.
Front suspension: Telescopic fork
Front wheel travel: 177 mm (6.97 in)
Rear suspension: Swingarm
Rear wheel travel: 173 mm (6.8 in)
Front tyre size: 100/90-R19 57H
Rear tyre size: 130/80-R17 65H
Front brake: Hydraulic twin discs 256 mm (10.08 in), twin piston sliding caliper
Rear brake: Hydraulic single disc 240 mm (9.4 in) single piston sliding caliper
Caster angle: 28º 23'
Trail length: 111 mm (4.37 in)
Fuel tank capacity: 17.5 litres (3.85 Imp Gal)
Engine
Type: Petrol, liquid cooled 4-stroke SOHC 52º V-twin, 4 valves per cylinder
Bore and Stroke: 81.0 x 66.0 mm (3.19 x 2.6 in)
Displacement: 680.2 cm³ (41.5 in³)
Compression Ratio: 10.0:1
Valve train: 4-valve, single chain driven SOHC
Lubrication system: Forced pressure with wet sump
Oil pump type: Trochoid/double rotor
Cooling system: Liquid cooled
Carburation
PGM-F1electronic fuel injection
Drive Train
Clutch system: Wet multi-plate, cable operated
Transmission: Constant mesh, 5 speeds
Primary reduction: ?
Final reduction: ?
Gear ratio 1st: ?
Gear ratio 2nd: ?
Gear ratio 3rd: ?
Gear ratio 4th: ?
Gear ratio 5th: ?
Gear-shift pattern: Left operated return system 1 - N - 2 - 3 - 4 - 5
Lubrication System
Engine oil capacity:
at draining ? Litres (? Imp qt, ? US qt)
at disassembly ? Litres (? Imp qt, ? US qt)
at filter change ? Litres (? Imp qt, ? US qt) Recommended engine oil: Honda 4-stroke oil or equivalent motor oil. API service classification: SE, SF or SG Viscosity.
Oil pump rotor:
Tip clearance: ? mm (? thou)
Body clearance: ? mm to ? mm (? thou to ? thou)
Rotor end float: ? mm to ? mm (? thou to ? thou)
Fuel System
Idle speed: ? ± ? rpm
Throttle grip free play: ? – ? mm (? - ? in)
Cooling System
Coolant capacity: Approximately ? litres.
Radiator cap opening pressure: ? to ? Psi (? to ? Bar)
Thermostat:
Opening temperature: ? to ?º C (? to ?º F)
Fully open: ?º C (?º F)
Valve lift: ? mm (? in) minimum Standard coolant concentration: 50% mixture with soft water
Cylinder Head / Valves
Valve clearances:
Inlet: ? to ? Mm (? thou to ? thou)
Exhaust: ? to ? mm (? thou to ? thou)
Clutch
Clutch lever free play: ? – ? mm (? to ? in)
Clutch spring free length: ? mm (? in)
Clutch disc thickness:
A (7 Discs): ? to ? Mm (? to ? in). Service limit: ? mm (? in)
B (1 Disc): ? to ? mm (? – ? in). Service limit: ? mm (? in) Clutch plate warpage service limit: ? mm (? in)
Front Wheel / Suspension / Steering
Cold tyre pressure, front: ? psi (? bar), Rider only
Cold tyre pressure, front: ? psi (? bar), Rider and pillion
Fork spring free length: ? mm (? in). Service limit: ? mm (? in)
Fork tube runout service limit: ? mm (? thou)
Fork oil type: 5 W fork oil
Fork oil level: ? mm (? in)
Fork oil capacity: ? cc
Rear Wheel / Suspension
Cold tyre pressure, rear: ? psi (? bar), Rider only
Cold tyre pressure, rear: ? psi (? bar), Rider and pillion
Drive chain slack: ? to ? mm (? to ? in)
Drive chain:
Disc Brakes
Specified Brake Fluid: Dot 4
Front brake disc thickness: ? mm (? in). Service limit: ? mm (? in).
Front brake disc maximum run-out: ? mm (? thou)
Rear brake disc thickness: ? mm (? in). Service limit: ? mm (? in).
Rear brake disc maximum run-out: ? mm (? thou)
Electrical System
Ignition System: Digital with electronic advance
Spark plug type: ? – standard.
Spark plug type: ? – high speed riding
Spark plug gap: ? – ? mm (? – ? thou)
Alternator: 12 Volts, ? Ah, ? W at 5000 rpm UK, ? W at 5000 rpm European
Regulator / Rectifier output: ? Volts at 5000 rpm
Headlight bulb: 60 / 55 Watts
Tail light bulb: 21 / 5 Watts
Speedo light: 1.7 Watts
High beam indicator: 1.7 Watts
Turn signal lights: 21 Watts
Turn signal indicator: 3.4 Watts x 2
Neutral indicator: 3.4 Watts
Oil pressure indicator: 1.7 Watts
Immobiliser (HISS) indicator: 3.4 Watts
Fuses: Main: 30 Amp, 10 Amp x 4, 15 Amp x 2 ??
Torque Values
Unless specified all bolts should be tightened to the following torque values.
Standard Fasteners N-m (kgf-m, lbf-ft):
5 mm Bolt and nut: 5 (0.5, 3.6)
6 mm Bolt and nut: 10 (1, 7)
8 mm Bolt and nut: 22 (2.2, 16)
10 mm Bolt and nut: 34 (3.5, 25)
12 mm Bolt and nut: 54 (5.5, 40)
5 mm Screw: 4 (0.4, 2.9)
6 mm Screw: 9 (0.9, 6.5)
6 mm Flange bolt (8 mm Head: Small flange): 9 (0.9, 6.5)
6 mm Flange bolt (8 mm Head: Large flange - engine only): 12 (1.2, 9)
6 mm Flange bolt (10 mm Head) and nut: 12 (1.2, 9)
8 mm Flange bolt and nut: 26 (2.7, 20)
10 mm Flange bolt and nut: 39 (4.0, 29)
Engine
Engine / transmission oil drain plug: ? N-m (? kgf-m, ? lbf-ft)
Engine / transmission oil filter: ? N-m (? kgf-m, ? lbf-ft)
Rocker arm adjusting screw locknut: ? N-m
Spark plugs: ? N-m
Front sprocket retainer plate bolts: ? N-m
Front Wheel / Brakes
Front axle shaft: ? N-m (? kgf-m, ? lbf-ft)
Front axle holder nuts: ? N-m (? kgf-m, ? lbf-ft)
Brake caliper mounting bolt: ? N-m (? kgf-m, ? lbf-ft)
Brake caliper bleed valves: ? N-m
Brake hose banjo bolts: ? N-m
Rear Wheel
Rear axle nut: ? N-m (? kgf-m, ? lbf-ft)
Rear sprocket nuts: ? N-m
Frame / Suspension
Front fork clamp bolts (bottom yoke): ? N-m
Front fork clamp bolts (top yoke): ? N-m
Front fork damper rod bolt: ? N-m
Front fork top bolt: ? N-m
Handlebar holder clamp bolts: ? N-m
Shock absorber mounting bolts nuts: ? N-m
Sidestand pivot bolt: ? N-m
Sidestand pivot bolt nut: ? N-m
Steering head bearing adjuster nut: ? N-m
Steering stem nut: ? N-m
Honda XL700V
Pictures
Dimensions
Frame
Engine
Carburation
Drive Train
Final reduction: ?
Gear ratio 1st: ?
Gear ratio 2nd: ?
Gear ratio 3rd: ?
Gear ratio 4th: ?
Gear ratio 5th: ?
Lubrication System
Oil pump rotor:
Fuel System
Cooling System
Thermostat:
Valve clearances:
Clutch
Drive chain:
Disc Brakes
Electrical System
Torque Values
Engine
Spark plugs: ? N-m
Rear Wheel
Frame / Suspension
